slodhi's avatar
slodhi
RAX75 individual bandwidth usage in the device list
It's all just shows 0.00 Mbps for all upload/download Internet usage for every single device.  QoS has been enabled and it’s showing flat out 0 for every device.
The router also has the latest firmware (Firmware Version V1.0.3.102_1.0.48), no further updates available at the moment.
  • plemans's avatar
    It should display whats actively being used for bandwidth.
    so if you're streaming 4k it will bounce between 0 and something like 20-30mbps. but it won't be a constant  number because most devices stream ahead (unless live/gaming)
    it doesn't display how much data has been used.
    • slodhi's avatar
      slodhi
      Thank you, plemans.
      We’re simultaneously streaming Roku (HD) and playing and/or downloading games on a gaming desktop via RAX75; none of its individual device indicator show any traffic (upload/download).
      However
      ADVANCED tab -> Advanced Setup -> Traffic Meter
      ADVANCED tab -> Show Statistics
      Both above show accumulative transmission of data and they’re functioning properly.  But I’m trying to pin point which individual device (IP/MAC address) is utilizing the most of the data and that’s where RAX75 is unable to perform.
      I’m hoping the technical team would look into it and may be the fix would be available soon.
