Mark1281
Jul 03, 2019Aspirant
2.4ghz slower speed on RAX80 AX8
MY ISP is 150MB down and on my previous Linksys router I could obtain that speed with no problem on the 2.4ghz band. ON my RAX 80 I can only get to 85MB on 2.4ghz, but no problem getting t...
Mark1281
Thanks, but I’ve done all that and no difference. Most of the clients are new and on prior router there was no issues.
schumaku
Jul 03, 2019Guru - Experienced User
Again: The RAX80 does (like any WiFi 6 device) run the 2.4 GHz and 5 GHz radio interfaces in an 802.1ax mode with a compatibility mode for older standard clients. So there can be interoperability issues - that's the risk of using the "latest" technology here. Your previous router was a WiFi6 (802.11ax) one on both 2.4 GHz and 5 GHz? Look, many Inhell 802.11n/802.1ac failed or badly struggled connecting reliably and on some standard performance against WiFi 6 access points before Intel has released driver updates.
"done all that" is rather useless - list the exact details of the WiFi interfaces in your devices and the driver versions for future reference.
