sahils's avatar
sahils
2x2 vs 1x1 MU-MIMO on RAX 120 vs RAX 80
Hi everyone,
I notice that the RAX80 supports "streaming on up to four 1x1 devices at the same time"  while the RAX120 supports "four 2x2 devices".
1. Is someone able to help me to understand why there is this difference? Both devices have 8 antennas but the RAX80 supports 8 streams while the RAX120 supports 12 streams?
2. How would this impact me (having RAX80 vs RAX120) as I migrate to WiFi 6 devices? I notice that devices being released nowadays often support 2x2 MU-MIMO (e.g. smartphones, tablets). Will the RAX80 also support 2x2 devices?
  • plemans's avatar
    RAX80: has 4x 2.4ghz antenna and 4x 5ghz antenna
    RAX120: has 4x 2.4ghz antenna and 8x 5ghz antenna.
    The RAX120 is a 12 stream versus the RAX80 is an 8. And the extra 4 are in the 5ghz band for 5ghz mu-mimo
    • sahils's avatar
      sahils
      Ah okay noted, thanks. But since RAX80 supports four streams of 1x1 devices, what about my 2x2 devices? Will RAX80 send 2 streams to my 2x2 devices? If so, how many 2x2 devices can it concurrently support?
      • plemans's avatar
        If it can support 4x concurrent 1x1 devices then it should be able to support 2x 2x2 solutions.
        You can have more devices running at the same time because they're usually rarely transmitting at the same time.
