trombeningen
Apr 07, 2019Guide
5G issues - SSID disappears
My RAX80 has stopped broadcasting the 5g network on all my 5g capable devices. Any suggestions on how to fix this? It appears randomly.
I reboot the router, 5G appears.
FW ver: V1.0.1.56_1.0....
Apr 07, 2019Guru - Experienced User
After you updated the firmware did you do a full reset of the device? The RAX80 is fairly new so firmware has been working through some bugs.
There's been a topic created on this issue that you could peruse and try some of the suggestions on there to see if they'll help you.
trombeningen
Apr 10, 2019Guide
Thank you, I think my problem is same as here.
After update, I've full reseted the router.
I use channel 60, it is not a DFS channel.
I have many devices have the latest updates for their operating systems and Wi-Fi drivers. Nintendo Switch, Xperia XZ2, Galaxy S10, etc.
