Cbmarsh39
Aug 22, 2025Follower
6ghz light off
I noticed recently the 6 ghz channel isn’t lit up anymore on my router. I can still connect to it, but in the app it now says unknown network for a device that’s connect to the 6 ghz channel (it’s a ...
Aug 22, 2025Guru - Experienced User
What model router is this?
Is the check box for enable 6Ghz radio uncheck in the routers WEB page UI? Basic tab or under Advanced Tab/Advanced Wireless Settings...
Try a factory reset and setup from scratch and see if it re-enables?
Is the 6Ghz signal seen by a wifi analyzer at all?
