Dustin_V
Sep 18, 2018NETGEAR Employee Retired
802.11ax WiFi: The Latest Internet Standard
The latest WiFi standard is here! With more and more connected devices entering our homes, the need for reliable connectivity and increased network capacity will be important to support ...
schumaku
Oct 24, 2018Guru - Experienced User
alokeprasad wrote:
Probably as useless as the 802.11ad on my R9000.
Nobody can state at this early point if the industry will pick up the new standard widely or if it will be ignored. While 802.11ad was nice, there are several disadvantages - the 60 GHz tech is expensive, requiring a lot of power, operating hot, and providing a physically limited reach.
Placesandspaces wrote:
Is there a list of ad devices? Sounds like they are few and far between.
Some 2014/15 Dell Latitude (also supporting the WiGig docking), and few leading edge Acer notebooks from around 2015/16. Most used Intel Wireless Gigabit modules. We had some success with updates, however the antennas are very hard to find.
Had a Dell Latitude with the dock for a project, trouble was if the cat was sleeping in between on the desk in the direct line of sight between the 60 GHz devices, the connection went bust. Similar limitations for 802.11ad of course.
Placesandspaces
Oct 24, 2018Apprentice
Interesting. Hopefully ax will have more success and benefits as well. Only time will tell.
