amonynuts
Mar 27, 2022Apprentice
Access Control device list does not show customer-configured Device Name
Nighthawk Router RAX45-100NAS AX4300 AX6, Firmware V1.0.10.110_2.0.75. Chrome browser.
In web-browser-based advanced configuration (routerlogin.net), the Access Control device list does not show customer-configured Device Name of connected devices after some time elapses. Note that the customer-configured device names are listed correctly in the "list of allowed devices not currently connected to the network", and on the Administration->Attached Devices page. Also, if any connected device in the Access Control list is edited, the device name appears correctly on the edit page and can be saved, at which point it appears --temporarily-- in the Access Control connected devices list (later all the names disappear, perhaps after DHCP address refresh, TBD).
It would be convenient to be able to see the Device Names of connected devices in the Access Control list.
- TC_in_MontanaVirtuoso
Double check the "user defined" device names you provided and insure that none have an extra space (or two) at the end.
This has been seen to mess up the device list in the access control list.
- amonynutsApprentice
Thank you for your suggestion. I did not have any "trailing" spaces in my user-defined device names, but I did have spaces in between words in my device names. After removing all the spaces (replacing some with hyphens and underscores), I have not seen this issue return for a few days. (Fingers crossed...)
I guess I had assumed that spaces were permissible in device names since there were no complaints when I entered them, but that seemingly causes problems displaying the access control connected-devices list.
Glad it resolved the problem.
Please make sure to mark the solution as accepted so that others can see what was done in case they run into the same issue.
