Chuckri
Mar 30, 2023Follower
Amazon Issue
Hello,
I have had the raxe500 for a little over a month now. I love the speeds on my tablet and phone. Unfortunately since swapping out routers my Amazon echo and show devices keep dropping off of the network. So have some of the smart lights that I have.
Anybody else having this issue or any suggestions how to fix it?
- KitsapMaster
Chuckri wrote:Hello,
You need to set your 2.4 GHz band for a 20 MHz wide channel only. iOT devices work better on the narrow channel and none of them require any bandwidth throughput. Set the channel selection to manual. The best channels are 1, 6, or 11.
What firmware version are you on?
what modem/gateway is it connected to?
