Xiong's avatar
Xiong
AX 12 Frequently disconnect from the unconnected network
v1.0.1.122 is the latest firmware. I cannot connect to the network, but the Wifi is connected normally. If there is no network, you need to restart the router to operate normally. The same problem exists when restoring factory settings.
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello Xiong,
    May you revert to the previous firmware version and see if the issue persists.
    Thanks,
    Christian
