Nukeman10
Mar 05, 2021Aspirant
AX12 Nighthawk RAX120 DHCP and reserve issues
Hi, I've got several network devices. Both Wired and Wireless. I decided for security reasons to enable Access Control. I took a whole night adding each of my static and dhcp items to it's allow list...
thehypnootoad
Mar 05, 2021Luminary
You are not on your own I have these issues too and seem others aswell. Try a pin hole reset it might sort itself abit mines calmed down for now but like you had to reserve ip addresses as dchp poops itself when first connecting.
- Nukeman10Mar 06, 2021Aspirant
I've tried, and had to use the pin hole to reset. Thx though.
Sure I was a little vague. Am I talking to the Router police or what.
I have about 125 devices that require IPs. I set about 15 of them static. The others are all anywhere from older 1.2 devices to several 5 GHz. Also have a few WIFI6 devices such as my phone. But to keep it short, DHCP is a mess on this $499 router. Look it up. Several others are suggesting the same thing. This is why Netgear makes us pay for support after so little time. What a racket.
And forget using this community to post frustrations on an important device that works like it was built in china.
LAter
