r_christison
Nov 04, 2020Initiate
AX120 total freeze up
Hi Folks hope someone has some guidance as sick of Netgear the way things are going!! updated to firmware V1.0.2.136 by direct link. system still keeps freezing up everyday around the ...
Newfiedrool
Nov 05, 2020Virtuoso
Have you performed a factory reset on the router?
if not I would start there using the rear pin method. Do not use a saved config profile. Set up as new and test.
Newfiedrool
Sorry just read you had reset.
I would reinstall the firmware over the top and try again with a reset.
if that fails I would test without the extender and see if there's an issue there.
- r_christisonNov 06, 2020Initiate
Tried that also,
RMA unit received today, and already noticed it's much faster internet and Wi-fi
unbelivablely the RMA unit comes with old firmware, but I don't trust the latest firmware at all, I think I will wait till Netgear do a revision as I think the problems came from it.
- NewfiedroolNov 06, 2020Virtuoso
Good to hear, the latest firmware is security and very important but it's up to you. I can say I'm on the latest and it's fine and my good friend has one too and it's fine.
