menana's avatar
menana
AX1800 Mesh WiFi 6 system firestick problem
Just purchased the AX1800 do to problems with our provide router by our ISP. We use firesticks to stream our entertainment.  I installed the router and the 2 satellites and then the firestick would not work.  Note: we have ClientVPN installed on our firesticks. Any ideas?
  • plemans's avatar
    what modem/gateway is the router connected to?
    What actual system do you have? AX1800 is a speed, not a model
    • menana's avatar
      menana
      The model is a mk63. The modem is one supplied by our ISP Spectrum. It doesn't have a make on it.
      • plemans's avatar
        some isp's supply modem/router combo devices which can cause a double nat and the occassional issue. does your modem have a model number on the label
