chriss232's avatar
chriss232
Follower
Jul 21, 2022
AX1800 needing constant reboots
Problem started recently, with the addition to two ring cameras to my network. I’ve not had any issues with this router in the past, except for signal coverage so I added a NG extender to the network. The router is 1 year old.
I’m having to reboot my router several times a day for the ring cameras. Today for instance, I had to do it twice in a two hour period, and no one was home using the network.
Prior to the cameras, I could run 3 phones a laptop, printer and a hardwired Xbox off the router simultaneously without issue. Now, the network won’t stay stable more than a few hours.
My firmware is up to date and other than simply needing a more powerful router, I can’t seem to find an issue. Is my problem really as simple as needing to upgrade my router?
1 Reply
  • plemans's avatar
    What actual router do you have? AX1800 is a speed, not a model.
    What firmware is on it?
    What modem/gateway is it connected to?
    What extender do you have?
    You don't actually put why you're having to reboot? what issue is happening to it that causes you to reboot?
