JayZz
Feb 07, 2021Follower
AX1800 (RAX10) no parent control feature
Hi Where are those parent control function in the old Netgear apps? After I upgraded this AX1800 router and installed the new nighthawk app, lots of good features are gone!!!! So disappointed!!
1 Reply
JayZz wrote:
After I upgraded this AX1800 router and installed the new nighthawk app, lots of good features are gone!!!!AX1800 could be one of several things. RAX20? RAX15? MK62?
Do you check the features before you bought the thing?
Netgear is trying to dump the free parental controls in favour of the paid for circle.
If your device does not support this, then join the pile of people asking for it to be added:
Idea Exchange For Home - NETGEAR Communities
