Michaelcc's avatar
Michaelcc
Follower
Dec 06, 2020
AX1800 RAX20 Router WPA3 Setting issues
Dear All,
I seek your help regarding the installation of WPA3 of my new AX1800 RAX20 Router.
When I click http://192.168.1.1 to change my wifi setting to WPA3 - Personnel, the wife network (the right hand corner of Window bar) doesn't let me to join.
When I change my wifi setting to WPA2-PSK, I can join my home wife network. Anybody can tell me what happen and how to change to WPA3 option. please
Michael
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi Michaelcc,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
