davidlwoolard's avatar
May 12, 2021
AX300 Ram
I have the above listed router and really love it.
My question is:  How much RAM does this WIFI Router for buffering issues.
I see newer WIFI routers that have 3Gigs and makes me think.
Thank you for the opportunity to post.
  • What router has 3gig or ram?
    Even the RAX200 only has 1gig.
    If you're referring to the RAX40 (AX3000 is a speed, not a model), it has 512mb ram.
    https://deviwiki.com/wiki/Netgear_RAX40_(Nighthawk_AX4)
    I never ran into buffering because of ram on a router and I've used a lot of routers. It tends to be a different reason you have buffering
1 Reply
  • plemans's avatar
