bepbep
Jul 30, 2020Aspirant
AX3000 Bad bandwidth wireless
I have a bunch of these routers in the field. There very clunky and the software being made is a bit worse every time a new version comes out it breaks some thing else. I have had issues with DHCP , then with the .64 load you can't surf at all cause of the disconnects. I have the 80 firmware and it seems a bit better but still just very clunky and with the WPS buttons on the front these Routers are not near what they should be. Is there any new software planned to be out very soon or I need to have them sent back to Netgear!!!
1 Reply
- Christian_RNETGEAR Employee Retired
Hello bepbep,
Thanks for sharing your feedback. Have you had a moment to get in contact with our support team regarding your issue(s)?
https://www.netgear.com/support/default.aspx
Christian
