treyley1's avatar
treyley1
Initiate
Feb 15, 2022
AX3000 Nighthawk AX4 model RAX35 no connection
Router shows all lights solid green but have no internet connection. The wireless connection is visible but never successfully connects. Have reset multiple times with the same results.
  • plemans's avatar
    what modem/gateway is it conected to?
    What firmware version are you on?
    Do wired devices work?
    • treyley1's avatar
      treyley1
      Initiate
      Connected to a charter modem ES2251 and can confirm I have internet without router. Not sure how to check firmware, The device itself is undetectable through app.
      • plemans's avatar
        If you hardwire a pc/laptop into the router, can you access the router that route?
        the status page will show the firmware version you're on.
