sterk03's avatar
sterk03
AX5400 RAX50
Netgear AX5400 RAX50 Some items to be controlled by wifi in your house demand 5g or 2g.
During setup which has been a while It seemed that the router picked the network based on what needed control or controlled by Wifi. So how would I connect say a light bulb that only wprked pm 2G to my wifi when all I can see is the main network and have no idea if it is attached to 5 or 2 G. Thanks in advance for any direction to this setup.
Thanks
Sterk03
    If a device only works on 2.4 GHz it will not see, or try to connect to, 5 GHz.
    Most devices use some sort of mobile app to get them to connect.
    Perhaps you could explain what you are trying to do.
    • sterk03's avatar
      sterk03
      Trying to hook up a wifi light bulb which has an app. It says it will only work on 2G. I sign in with to my router network and password but the bulb will not pair with the app and I have no idea if the network is 5 or 2G and so I am not sure the bulb will seek out a 2G network and the Netgear should see this and sign in.
      Best I can describe it.  Online you then can change on/off color schedule.
      Thanks for your reply.
      Sterk03
