Matpeakrock
Aug 14, 2024Follower
AX5400 Router to modem not connecting
I have a older Nighthawk in use right now, I am trying to connect my new AX5400 and will not connect to the ISP modem. (red light is still on) What direction should I look for. Thanks in advance for any sugestions.
Start by looking up the actual product number on the bottom of the router. AX5400 is a marketing claim that applies to a host of different products.
When replacing user equipment, it is customary to reboot the ISP device (modem) and then power up the user device.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
