anicaretta3's avatar
anicaretta3
Ax5400/Rax50 Smb Version Supported
Does anyone know which Smb versions are supported by the RAX50/AX5400? Tech support was unable to provide an answer and I don’t want to end up in the same situation that I currently have with my WNR4500/N9000 where it only supports Smb 1.0. Thanks in advance!
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
    Thank you.
  • FURRYe38's avatar
    You might as a forum moderator and see if they can tell you.
    Though from this users post, his RAX80 series seems to be working with Windows 11 and USB storage so this would kind of inidicate SMB version being used would be something other than v1.
    • anicaretta3's avatar
      anicaretta3
      That makes sense, hopefully that is the case. I'll post over there and take a look at the other posts, thanks!
