jingstar
Jun 25, 2024Aspirant
AX6600 Rax70 once connect Seagate 8TB HDD for Readyshare, router reboot itself constantly
I have a Nighthawk AX6600 Rax70, used without any issue at all, however, whenever i connect a hard drive to its usb3 port (HDD has its own power cable), tried Seagate 3TB, Seagate 8TB, it always cons...
jingstar
Aug 26, 2024Aspirant
I have checked that time that i have the latest version which is Router Firmware Version V1.0.15.146.
when i connect Seagate 8TB HDD to router's usb3, occassionally router will frequently disconnect itself from internet, that is the indicator turns to orange from white color, and i just simply doesn't have internet, need to hard restart router again to get my internet back again, but after about half hour, it losts internet again. However, once i dont connect HDD to the router, everything fine, no disconnection at all.
- FURRYe38Aug 26, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
