Vincy's avatar
Vincy
AX8 AX5700 (RAX75) Management Software freeze every day along with the AD7000 (R8900)
I bought this AX8 AX5700 (RAX75) (unfortunately, costco model is not even showing up in the dropdown...) router from Costco to replace my AD7000 (R8900)which also bought from Costco.  I did the firmware updates as soon as it forced me to complete admin setup.  I then set up the router the way I wanted.  I then enabed the Access Control and noticed same problem I have encountered in R8900.  The Device Names are not showing up for most of the devices.  I then noticed, some of the device that are on the network aren't even showing up in the access control list and some of them show up in offline list.  They are connected becasue I did not enabled the Access Control at the beginning, that means when i enabled the Access Control, they are all fall under the allowed list but not showing up in the Management software.  In addition, when I try to customize the name either from N/A or Unknown, and save, at least 50% of the time, I get "router did not sent any data".  Not sure what that means but my changes weren't saved.  Furthermore, sometime I even get session timeout even though I was going between pages.  So, is that mean Access Control page has its own weird session management???
That was first day story.
Next day, I wanted to setup R8900 as Wireless Bridge from the living room to connect my Media Center which includes, TV, AV Receiver, BluRay and sometime my Macbook for troubleshooting the bridged router.  So, the moment I setup the Wireless Bridge, in few minutes, i noticed that I cannot even get to AX8 managment software from any sources like Browser, Nighthawk iOS app, Windows Genie app, Mac Genie app (Mac app is keep crashing...).  The management software just freezes on me and the only way I can fix this is by powering if off and back on.  It has been like a week now, and noticed, this became a every day routine for me.  I also tried, resetting from software as well as hard reset from the reset button but none of it worked.  To ruin my peace of mind more, I also noticed that my Wireless Bridge is also freezing up.  The weird part is, from most of the devices, I can still connect to internet but not the AppleTV, it just jumps to 169, local ip address.  So, have any of you noticed this behavior with AX8 does not matter whether it is RAX75 or RAX80, I assume they both have the same management software.... unless I am mistaken?
For R8900, I opened a few support tickets on Netgear website, the only response i got from them when I gave them the remote access to see my problem is, they do not have device to test the issue on their end!  What a marvellous support, isn't it?
Oh! forgot to mention, for most of the time, the Access Control and Attached Devicesscreen only show first 20 devices.  However, in the count it says, 26 devices are connected but trust me I have a few more than that on the network... and i certainly don't think Netgear QA and UAT has done any testing its full strenght of their Management Software even though they advertize it as 25+ devices... BIZARRE!!!
Just noticed on the AX8 Access control with 169 ip address and in allowed list with the non-existent mac address.  Also, noticed when all the connected devices to this bridge showing up as this mac address instead of actual device mac address.  I have R6300 and R7000 bridged wirelessly as well but they all work without this issue but this R8900 acts just like Netgear!
Allowed R8900 169.254.7.76 8C:3B:AD:B1:5D:AA
Hope, someone has some suggestions here, otherwise, i think it is now time for me to say goodbye netgear for ever...
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
  • I'd deal with that pule of issues one at a time. They do not seem to be related.
    Maybe other people with more expertise will be able to pick up those issues.
    I'll start with this one:
    What is your idea of a Wireless Bridge?
    I ask because people turn up here with different interpretations of "bridge", not helped by Netgear's own indiscriminate use of the label.
    You want the R8900 to talk to wifi on the RAX75 and to pass it on to other devices?
    You want to wire the R8900 to the RAX75 and act as a wifi access point?
    You have been through everything in the manual for the R8900?
    There is a manual for the R8900 somewhere at the end of this link:
    >> Click here >> R8900 | Product | Support | NETGEAR << Click here <<
    See the section Set Up the Router in Bridge Mode.
    I very much doubt if you are mistaken.
    That you can't get into the graphical user interface (GUI) is a bummer. What sits at the front of the network? The modem?
    • Vincy's avatar
      Vincy
      Thanks Michael for your response.  About the duplicate of post that is honestly not my fault.  Even after selecting the right options from dropdowns, Netgear put my post in wrong place which I do not what is what until someone said, you better off posting this on WiFi 6 blog.  I am in IT industry since 90s and when i design a website I do not make user to guess where the user should be but design such a way, based on the selections I take them to the right place.  That is called "User Friendly!"  I think, Netgear never heard of it, unfortunately!
      Anyway, please see my responses in red:
      All the devices, nowadays, come with both LAN port and built-in wireless, however, built-in wireless have bandwidth limitations.  But, all the LAN ports have Gigabit through put.  Therefore, I use my old routers as Wireless Bridge to bridge two routers wirelessly and use the LAN ports to connect my device with either Cat 5E or Cat 7 cables where I see more than double throughput.  I have R6300 and R7000 bridged for serveral years and they both serve me flawlessly.  But, the problem is with latest and greatest devices from Netgear which are not tested thorougly in my opinion and based on the response I have seen from the support people.
      I explained it above...
      Yes, on LAN ports wired.
      No, They are at least 50ft away from each other.  RAX75 is on upper floor in the guest bedroom and the R8900 is in main floor in the living room.  From the same distance, when I upgraded R6300 to R7000, I bridged the R6300 to R7000 and when I upgraded R7000 to R8900, I bridged R7000 to R8900 and had no problems.  I also bridged R6300 from my Master Bedroom to R8900 and now RAX75 and see no issues.  I took my R8900 down yesterday, put my R7000 on main floor again and so far I have not seen freeze.  If this continues then I can tell for sure that R8900 and RAX75 are not compatible to bridge them wirelessly but will have to wait next few days to come to that conclusion.  If that is the case then its a bummer!
      As per Netgear, if I understand it correctly,  when you wirelessly bridge the two routers, it will also link them and I assume it works like a Access point based on the wireless device that is on the network.  NOT SURE!  But, this is what the manual says but I do not care this feature at all and my intention is to make use of gigabit LAN ports:
      You can use your router in bridge mode to connect multiple devices wirelessly at the faster 802.11ac speed. You need two routers: one set up as a router and the other set up as a bridge.
      Installing your router as a bridge offers the following benefits:
      • Take advantage of gigabit WiFi speeds on current devices
      • Use Gigabit WiFi for applications like video and gaming.
      • Connect multiple devices like NAS, Smart TV, Blu-ray player, and game consoles at gigabit WiFi speeds using a WiFi link. (not sure what this means)
      • Avoid the need for separate WiFi adapters for each device.
      There is nothing special to configure for what I am doing in any of those three routers, all the steps remained same for my purpose.  Whatever additional feature R8900 has it, I am not using them, so it does not matter to me.  Yes, I have went through all the instructions from Netgear!
      Also, about the Management software, you cannot rely on Netgear!  There is a day and night difference between, R8900 and RAX75 software.
      No, I don't have anything in front of the RAX75 but behind it has AT&T as the Gigabit Modem and router which supplies internet connection to RAX75.  It is not like anythng else is interfering with the router becasue in the end, I am not new to what i am doing here.  I am doing this for at least 5 years if not more.  Like, I said, the problems started as I start adding devices around the house.  Their firmware as not sophisticated enough to handle many devices and whatever database they have in the firmware it totally useless and that is why you see different statistics about the connected devices from difference interfaces to its Management Portal.  I showed them to the support but they had no answers, I don't even think that they convey these bugs to the engineers, to be honest!  They just want to bring the new technology to the market to make money as much as possible.  I was married to DLink before i tried R6300 from Netgear.  Only, DLink and Netgear has better User Inface for the Management Software.  I rate DLink number one in that perspective, the last rounter i used was DIR-825 and i still have it and use it as a switch by putting DD-WRT firmware in it.  But the sad part of DLink is they have fallen behind the technology and that why I had to switch Netgear but loved the R6300 and R7000 and still use them.
      • Vincy's avatar
        Vincy
        Alright, Netgear removed my font color after submitting my last response except for one little thing!  WYSWYG does not play here! LOL!  it is WYSNWYG!
