FlaBouy's avatar
FlaBouy
AX80 connection issues
My R9000 went down a few weeks ago and Netgear sent me a remanufactured AX80 replacement.We won't go back through all of the issues that caused, but I have found work arounds for nearly all of the other issues but this. Internet drop outs on a hard wired connection. I tried anouther brand new cable modem and a fresh install of Chrome to eliminate those two factors, but I am still seeing a steady stream of drop outs as indicated by the attached logs.
Any ideas since Netgear support will not respond to the support ticket anymore?
  • plemans's avatar
    What modem do you have?
    What firmware is on the router?
    • FlaBouy's avatar
      FlaBouy
      Modem is an Arrix SB8200.
      Firmware is latest V1.0.3.102_1.0.48 that was manually uploaded after the latest .50 firmware was buggy. Modem rebooted after firmware upgrade.
      Network and internet connectivity works fine when Archer A7 router is swapped in place of the AX80.
      • plemans's avatar
        After the firmware change did you attempt a factory reset?
        Also the SB8200 has 2x ethernet ports but only 1 is usable for the average user. Make sure only 1 device is connected
