Retired_Member
Oct 09, 2022Built in VPN with IPhone
I have a problem connecting my phone to Local network.
I enabled built in VPN and DDNS on RAX 48 router.
Then i downloaded the Smart Phone Config and exported to my Iphone. Followed these steps: https://kb.netgear.com/29826/How-do-I-use-VPN-on-my-NETGEAR-router-with-my-iOS-device
When i go on to connect on OpenVPN connect app, it says connection Failed. Network is unavailable when i try it on Cellular.
If i try on WIFI, it attempts to connect and fails.
The instructions i see on youtube, they enter password and cert when importing config to a phone. But when i import it, it doesn't ask me to. It has a lock
- iyangNETGEAR Expert
Hi Retired_Member ,
Do you install openvpn app in your iPhone ?
And do you put openvpn certification to your iPhone ?
Thanks.
- Retired_Member
on my iphone.
there's really no way to import a certificate. Also inside of Config file that i got from Netgear built in openVPN, it already has certificate.
