carson_adkins's avatar
carson_adkins
Apprentice
Jul 09, 2020
cable connection from comcast to cax80 frequencies and internal logs
just curious about this stuff i have a bunch of errors in the modem
Frequency start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel507 MHzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnabledBPI+
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1Locked256 QAM5507000000 Hz-0.5 dBmV41.4 dB00
2Locked256 QAM1483000000 Hz-0.2 dBmV41.6 dB00
3Locked256 QAM2489000000 Hz-0.4 dBmV41.5 dB00
4Locked256 QAM3495000000 Hz-0.3 dBmV41.5 dB00
5Locked256 QAM4501000000 Hz-0.4 dBmV41.4 dB00
6Locked256 QAM6513000000 Hz-0.6 dBmV41.3 dB00
7Locked256 QAM7519000000 Hz-0.6 dBmV41.4 dB00
8Locked256 QAM8525000000 Hz-0.8 dBmV41.3 dB00
9Locked256 QAM9531000000 Hz-0.8 dBmV41.2 dB00
10Locked256 QAM10537000000 Hz-1.0 dBmV41.2 dB00
11Locked256 QAM11543000000 Hz-1.3 dBmV41.0 dB00
12Locked256 QAM12549000000 Hz-1.3 dBmV41.0 dB00
13Locked256 QAM13555000000 Hz-1.3 dBmV41.0 dB00
14Locked256 QAM14561000000 Hz-1.3 dBmV40.9 dB00
15Locked256 QAM15567000000 Hz-1.4 dBmV40.9 dB00
16Locked256 QAM16573000000 Hz-1.8 dBmV40.7 dB00
17Locked256 QAM17579000000 Hz-2.0 dBmV40.5 dB00
18Locked256 QAM18585000000 Hz-2.1 dBmV40.5 dB00
19Locked256 QAM19591000000 Hz-2.3 dBmV40.4 dB00
20Locked256 QAM20597000000 Hz-2.2 dBmV40.3 dB00
21Locked256 QAM21603000000 Hz-2.4 dBmV40.1 dB00
22Locked256 QAM22609000000 Hz-2.6 dBmV40.1 dB00
23Locked256 QAM23615000000 Hz-2.7 dBmV40.1 dB00
24Locked256 QAM33459000000 Hz0.0 dBmV41.8 dB00
25Locked256 QAM34465000000 Hz-0.1 dBmV41.5 dB00
26Locked256 QAM35471000000 Hz-0.2 dBmV41.5 dB00
27Locked256 QAM36477000000 Hz-0.3 dBmV41.5 dB00
28Locked256 QAM38429000000 Hz0.7 dBmV42.2 dB00
29Locked256 QAM39435000000 Hz0.6 dBmV42.0 dB00
30Locked256 QAM40441000000 Hz0.1 dBmV41.7 dB00
31Locked256 QAM41453000000 Hz0.1 dBmV41.9 dB00
32Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA625120 Ksym/sec29400000 Hz41.5 dBmV
2LockedATDMA615120 Ksym/sec35800000 Hz41.5 dBmV
3LockedATDMA635120 Ksym/sec23000000 Hz40.5 dBmV
4LockedATDMA15120 Ksym/sec16600000 Hz39.8 dBmV
5Not LockedUnknown0000.0 dBmV
6Not LockedUnknown0000.0 dBmV
7Not LockedUnknown0000.0 dBmV
8Not LockedUnknown0000.0 dBmV
Downstream OFDM Channels
ChannelLock
Status
Modulation /
Profile ID
Channel
ID
FrequencyPowerSNR /
MER
Active Subcarrier
Number Range
Unerrored
Codewords
Correctable
Codewords
Uncorrectable
Codewords
1Locked0 ,1 ,2 ,337690000000 Hz-2.02 dBmV39.4 dB1228 ~ 28671988813141654555440
2Not Locked000 Hz0 dBmV0 dB0 ~ 4095000
Upstream OFDMA Channels
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPower
1Not Locked000 Hz0 dBmV
Extended Upstream Transmit PowerEnable Extended Upstream Transmit Power
TimePriorityDescription
Thu Jul 9 13:00:00 2020Notice (6)TLV-11 - unrecognized OID;CM-MAC=08:36:c9:3e:86:b8;CMTS-MAC=00:01:5c:82:fc:79;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:52 1970Notice (6)Honoring MDD; IP provisioning mode = IPv6
Thu Jan 1 00:00:48 1970Critical (3)No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:3e:86:b8;CMTS-MAC=00:01:5c:82:fc:79;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:44 1970Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:86:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:50 1970Critical (3)No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:3e:86:b8;CMTS-MAC=00:01:5c:82:fc:79;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 9 12:44:36 2020Critical (3)Resetting the cable modem due to docsDevResetNow
Wed Jul 8 13:01:15 2020Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:86:b8;CMTS-MAC=00:01:5c:82:fc:79;CM-QOS=1.1;CM-VER=3.1;
Wed Jul 8 12:54:03 2020Critical (3)SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=08:36:c9:3e:86:b8;CMTS-MAC=00:01:5c:82:fc:79;CM-QOS=1.1;CM-VER=3.1;
Wed Jul 8 12:51:01 2020Critical (3)SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=08:36:c9:3e:86:b8;CMTS-MAC=00:01:5c:82:fc:79;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:03:18 1970Critical (3)No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:3e:86:b8;CMTS-MAC=00:01:5c:82:fc:79;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:02:38 1970Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:86:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:01:26 1970Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3e:86:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
  • These are normal errors that occur when the device is ranging (when it is coming online/initializing). The TLV11 errors can be ignored, that just means there was something the in the cable modem config file that the modem did not recognize, the modem just ignores these and moves on.
    • carson_adkins's avatar
      carson_adkins
      Apprentice
      well it doesn't seem like it is taking the gigabit speed so I thought that this could be the problem but I guess it's Comcast not provisioning my router right
      • dusteraz's avatar
        dusteraz
        What are your speedtest results and how are you doing the speedtest? What I noticed is I get around 500 Mbps using the integrated speedtest but I an get 900+ fine with my PC that is wired directly.
