wilcoxmj's avatar
wilcoxmj
Can I add an external PoE Access Point to a RAX120
Hi,
I have a RAX120 which provides great wireless signal inside my house - no complaints there.  However outside the house I have next to no signal, which is challenging for my wireless security cameras, and wanting to get a signal into my workshop (seperate from house).
My question is, can i add in an external AP with a PoE injector to one of the LAN ports on my RAX120?  Unfortunately hard cabling out to my workshop isnt an option. And I am unable to move the RAX120 location, due to the proximity of the NBN entry to my house.
Thanks in advance
  • The RAX120 does not have PoE LAN ports, if I understand your question correctly
    • wilcoxmj's avatar
      wilcoxmj
      Yes - I know it doesn’t have PoE LAN ports, however would an external antennae with a PoE injector work for me to put an external/outdoor access point on the Wi-Fi network
  • michaelkenward's avatar
    michaelkenward
    It might be safer, and simpler, to investigate Powerline Ethernet and, if you need wifi, to put a wireless access point on the remote plug. You can even  by Powerline plugs that have a built in AP.
    I have an Orbi in AP mode at the remote end of a Powerline network. Works fine.
    • antinode's avatar
      antinode
      Guru
      > Should work
         I don't see why it would cause any special problems.  Whether it
      would solve the basic problem is a different question.
      > [...] Unfortunately hard cabling out to my workshop isnt an option.
         So, without "hard cabling", what, exactly, would the "an external AP"
      be buying you?  Shorter distance to the still-remote "workshop"?
         How/why, exactly, would that be "safer" or "simpler"?  It might be
      more _effective_ in getting a wired network connection in the
      "workshop".
      • wilcoxmj's avatar
        wilcoxmj
        In short yes - a shorter distance to the workshop, I can hard cable from the router to the edge of the house, but can’t get across the 10m of gap without stringing a catenary wire or going underground.
    • wilcoxmj's avatar
      wilcoxmj
      Thanks - not knowing a great deal about powerline, would it still be applicable if the sockets are on completely different electrical circuits? (I’m guessing the answer is no)
