aliklois
Sep 02, 2024Aspirant
Can someone help me set up my Netgear Nighthawk router?
I'm struggling to set up my Netgear Nighthawk router with my modem. Tried resetting both but no luck. Any advice?
michaelkenward
Sep 02, 2024Guru - Experienced User
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
That page will also have any software, firmware and drivers for your device, if they exist.
Begin with the Quick Start/Installation Guide.
There may also be some helpful videos on what to do.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
Just another user with time on their hands.
- alikloisSep 18, 2024Aspirant
thanku very much for the help
