aliklois
Sep 02, 2024Aspirant
Can someone help me set up my Netgear Nighthawk router?
I'm struggling to set up my Netgear Nighthawk router with my modem. Tried resetting both but no luck. Any advice?
Sep 02, 2024Guru - Experienced User
What model # NH router do you have? R or RAX or RAXE###?
What brand and model# ISP modem or ONT do you have connected to the NH router?
Power off both ISP modem/ONT and NH router for 30 seconds then back ON with the ISP modem/ONT then turn ON the NH router...
aliklois
Sep 20, 2024Aspirant
- michaelkenwardSep 20, 2024Guru - Experienced User
aliklois wrote:
I have an RAX router and an ISP modem, will power cycle both as instructed.
Which ones? Especially the modem. Make and model?
Just another user with time on their hands.
