jvhaslup's avatar
Oct 02, 2020
Can the RAX200 be configured as an access point?
Just getting fiber optic to the house today,  and the tech has a CenturyLink 3960 (Zyxel C3000Z) modem/router combo in my garage.
Due to the overall weak signal, I'm hoping to reconfigure my RAX 200 as an access point, in order for all my WiFi devices to connect.
I'd prefer to switch out the Zyxel modem/router for my RAX 200 router and my AC1200 modem - Has anyone done this ?
R,
Jim
1 Reply
  • plemans's avatar
    The RAX200 does have access point mode and it works well in access point mode.
    I doubt you can switch out the Zyxel C3000Z since centurylink would need a compatible modem/gateway. If you have one that is indeed compatible, then it might be a different.
