btjones34711
Mar 02, 2019Aspirant
Can you connect two AX6000 routers using "ethernet port aggregation"?
Is it possible to connect one (1) AX6000 to a second AX6000 that is setup in "Access Point Mode" using "Ethernet port aggregation"? Something like the attached...
microchip8
Mar 02, 2019Master
why don't you try it and tell us? Also, there may be something about that in the manual PDF. Look it up on what it supports
