Ashour
Mar 26, 2023Aspirant
Cannot connect ps5
my PS5 can detect the wifi but not connect to it
any one can help?
Sort By
- microchip8MasterNo.. not unless you provide really basic info
which router model?
which frimware version?
which band are you trying to connect the PS5? 2.4 or 5/6 GHz?- AshourAspirant
I'm sorry I'm not an expert in this
- Nighthawk Wi-Fi 5 AC
- V1.2.8.40
- I'm trying to connect to 2.4
I'm using smart connect (2.4 5.6) I'm not sure if thats wise or not
I did reset the router but still issue happens
everything else connects fine
(PS5 is not on my blocked list)
if I use another router ps5 connects just fine
- microchip8MasterNighthawk WiFi 5 AC is not a model, it's a WiFi class. Look at the label of your device, most likely it starts as Rxxxx (eg, R7000, R7800, etc)
First thing I'd try is disable Smart connect and name your 2 bands (SSIDs) differently, then try again and report.
