flyfish
Oct 25, 2025Aspirant
can't log into router
I have a RAXE500 Netgear router firmware version v1.2.14.114. I am unable to get access to this router with any method. The ip address doesn't work and the web address takes me to the netgear website...
flyfish
Oct 26, 2025Aspirant
Well, I was able to reset everything, but I still can't log into the router.
No matter what I put in it takes me to Netgear's site.
I'm lost.
Oct 26, 2025Guru - Experienced User
And you reset the router with out it being connected to the ONT?
- flyfishOct 26, 2025Aspirant
Yes. The only thing plugin was the power cord. I also rebooted the ONT.
- FURRYe38Oct 26, 2025Guru - Experienced User
So if the router is disconnected from the ONT and factory reset and give 1 minute, can you not get to the routers setup wizard page at 192.168.1.1. You should see a page here picturing using the Nighthawk mobile app, then if you scroll down to the bottom of this page, you should see a link that says don't have the nighthawk app or mobile device, click this link.
