flyfish
Oct 25, 2025Aspirant
can't log into router
I have a RAXE500 Netgear router firmware version v1.2.14.114. I am unable to get access to this router with any method. The ip address doesn't work and the web address takes me to the netgear website...
flyfish
Oct 26, 2025Aspirant
Yes. The only thing plugin was the power cord. I also rebooted the ONT.
Oct 26, 2025Guru - Experienced User
So if the router is disconnected from the ONT and factory reset and give 1 minute, can you not get to the routers setup wizard page at 192.168.1.1. You should see a page here picturing using the Nighthawk mobile app, then if you scroll down to the bottom of this page, you should see a link that says don't have the nighthawk app or mobile device, click this link.
