flyfish
Oct 25, 2025Aspirant
can't log into router
I have a RAXE500 Netgear router firmware version v1.2.14.114. I am unable to get access to this router with any method. The ip address doesn't work and the web address takes me to the netgear website...
flyfish
Oct 27, 2025Aspirant
I used 192.168.1.1 and 192.168.0.1 also http://www.routerlogin.net and http://www.routerlogin.com.
All of these took me to:
NETGEAR Router Login
Learn how to configure your router by choosing a path below.
I never got a login page.
Oct 27, 2025Guru - Experienced User
Something to try, disconnect the router from everything.
Perform a 30-30-30 reset on the router. Use a timer for this.
Once you complete the past 30 second reset button press and release, connect one ethernet PC to the back of the router and see if you can access the setup wizard at 192.168.1.1.
If you can, then router has failed and needs replacing.
flyfish wrote:I used 192.168.1.1 and 192.168.0.1 also http://www.routerlogin.net and http://www.routerlogin.com.
