emerywang
May 07, 2020Aspirant
Can't see router from wired PC, RAX15
Hi. I have an AX1800/RAX15 router, just bought it last week. It's not listed in the models dropdown menu so couldn't select the model.
Anyway, it works fine and I can access it thru router.com on my laptop connected wirelessly. But my wired PC, which is direct wired into a switch that is wired to the router, can't access the router via router.com. I also can't see any wireless printers connected to the RAX15 from my wired pc.
I didn't have this problem with my previous wireless router, which was set up the same way.
Any ideas?
Thanks.
1. what modem are you using?
2. what firmware is on the RAX?3. What switch are you using?
4. Are you in a double nat? it can cause issues with the routerlogin connect as well as possible the printers as well. https://kb.netgear.com/30186/What-is-Double-NAT
5. do you have your computer set to "private" connection in windows? Or public? it might not "find" the printers if its on public.
- emerywangAspirant
Thanks Plemans. I figured out the problem. Our IT guy recently set up a VPN for us to connect to the office from home, and it can't see the router when the VPN is on. Disabling the VPN fixed it.
I appreciate the help.
-Emery
