myslad's avatar
myslad
CAX30 — Nighthawk AX6 6-Stream WiFi 6 Cable Modem Router
Whats the maximum dowload speed that we can expect. I have xfinity 1.2 gig connection
I get only 200 MBps, with wired connection?
Any settings need to be tuned?
  • plemans's avatar
    Its a docsis 3.1 device. It should support gig+ speeds.
    Do you have a screen snip of the cable connctions page and the event logs?
    That lets us check your connection
      • plemans's avatar
        photos can take a bit to be approved as a moderator has to approve them
