Smart_user
Feb 16, 2022Follower
CAX80 warranty
NETGEAR closed my warranty case 3 days before the warranty expired without solving the problem.
The issue was a known issue - no WIFI calling with Samsung phones, wifi calling works okay iwth IPhone
It is now impossible to contact them throught the online system.
Anyone else have a problem with shutting down warranty claims?
What did you do?
{note I was not able to select the model of CAX80 or AX6000 , the model is not listed as an option)
1 Reply
sadly, its something you'll have to go through support for if its a warranty claim.
The wifi calling is a different issue. If you do a quick search on samsung wifi calling not working, you'll find a ton of results.
