bd2's avatar
bd2
Changing modem for my RAX45
I am thinking of upgrading my modem. I currently have a Nighthawk AX4300 6 Stream router. What kind of setup work will I have to do with the router once I change the modem?
  • plemans's avatar
    The best bet?
    Check with your isp to see what's compatible. We can recommend all kinds of things but if its not compatible with your isp, its a bit pointless.
    • bd2's avatar
      bd2
      Thank you! I am just wondering what kind of changes need to be made to the router if I install a new modem (CM1100 for example)?
      • plemans's avatar
        What modem do you have? Is it just a modem, is it a modem/router combo device?
        If its simply a modem, get the modem activated first.
        then power it off, hook up the router (powered off), power on the modem, give it a few minutes and then power on the router.
    • antinode's avatar
      antinode
      Guru
      > I am thinking of upgrading my modem. [...]
         From what to what?
      > [...] What kind of setup work will I have to do with the router once I
      > change the modem?
         If all you're doing is a modem swap, then I wouldn't expect any.  If
      your (unspecified) "my modem" were actually a modem+router, then things
      might get more complicated.
         Your ISP might be interested in the MAC address of the new modem, but
      I don't see why the router would care about such a change.
      • bd2's avatar
        bd2
        I am currently using a Motorola Surfboard SB6121 modem (modem only) which my RAX45 router is connected to. I want to change that out for the CM1100. I didn't know if I would have to change any settings on the router once I switched over. Or if it just entailed restarting the router after the new modem was installed.
