ExplorzTutorDec 27, 2023charger connector diameter RAX50I need to buy a replacement adapter charger for my RAX50. Does anyone know the proper barrel connector diameter? It's 5.5MM outer. But is the inner 2.5mm or 2.1mm? Thank you.
1 ReplyReplies sorted by OldestFURRYe38Guru - Experienced UserDec 27, 2023One of these should work: https://www.amazon.com/s?k=rax50+power+adapter&crid=3HPSS58SBIAV5&sprefix=rax50+power+adapter%2Caps%2C150&ref=nb_sb_noss
