drugrep's avatar
drugrep
Check for update failing (1.0.2.82 to 1.0.2.94)
(Using RAX45, model selector above won't let me select that version.
the following has been true of past 2 updates also.
I noticed today 1.0.2.94 was posted.
I had the router check for update and it stated "No new firmware version available."
I manually updated, and now on V1.0.2.94_2.0.58. I was on V1.0.2.82_2.0.50
Something wrong with auto update / check for update.
  • plemans's avatar
    sometimes the manual update server gets the update prior to the auto-update server.
    And sometimes its opposite where the auto-update gets it first.
    Not sure why it works like that.
    • drugrep's avatar
      drugrep
      Well, neither had it and I had to manually download it from the website.
