jimerb's avatar
jimerb
Cielo Breez Plus Keeps Disconnecting From Wifi
I'm trying to get this Cielo Breez Plus Smart Air Conditioner Controller  to not disconnect every 10-15 minutes.   The device will only connects only to a 2.4ghz channel.  It connects fine but then drops.   The device is about 10 feet away from my Nighthawk RAX200 router.   The device itself has no options for connecting -- it's very basic.
Can anyone give me some suggestions on what I can tweak on the router side?  My current config:
  • 20/40mhz coexistance unchecked.
  • Broadcasting on channel 1
  • Mode up to 1200 mbps
  • Transmit power control 100%
  • Fragmentation Length: 2346
  •  CTS/RTS Threshold: 2347
Cielo's tech support is not being much help.
Can anyone give me some guidance?  Things to try?
  • FURRYe38's avatar
    Something to contact the Mfr of this device to get help regarding there product.
    A couple of suggestions for testing.
    Change the broadcast channel.  Next best options are channel 6 or channel 11.
    Lower the transmit power to 25% or 50%, you may be overwhelming the controller with signal.
    Enable the 20/40 coexistance.
    • jimerb's avatar
      jimerb
      Thank you! I will try these things.  Most of these settings are way over my head.
