denadean
Oct 19, 2020Aspirant
Coaxial cable connection to Nighthawk MK62
I recently purchased the Nighthawk Mesh Wifi 6 system AX1800, MK62. My ISP is Verizon Fios. The modem is located deep in a closet by my front door and then a coaxial cable runs from the modem to my living room where it had been connected directly in an old router.
I realized once the Nighthawk system arrived that there was no port for the coaxial cable. I thought that I could put the coaxial cable in the living room into the moca, and then connect the moca to the Nighthawk system via ethernet, but that is not working.
What do people recommend as a solution to get my Nighthawk working with my Verizon Fios internet?
Thanks so much!
d
- denadeanAspirant
I should mention the moca i purchased is the motorola bonded 2.0 for ethernet over coax.
- Christian_RNETGEAR Employee Retired
Hello denadean,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- denadeanAspirantI did. They suck. Four techs couldn't figure out what I finally was able to troubleshoot myself by watching YouTube videos. Frankly this company doesn't deserve a dime of my money.
