Retired_Member's avatar
Retired_Member
Jul 12, 2021
Connect MR60 Satellite to Orbi AX6000 router
Does the new Orbi AX6000 router connect to MR60 WiFi6 Satellite? The existing MR60 Satellite is a small cabinet hence do not want to replace it with another Orbi AX6000 Satellite.
Thanks
  • plemans's avatar
    the orbi systems and the MK sysstems are not compatible.
    They won't integrate together.
    • Retired_Member's avatar
      Retired_Member
      Thanks for taking time to reply... much appreciated.
