tommy0629
May 01, 2023Aspirant
Connecting Nighthawk RAX54 to Samsung Galaxy S21 Ultra to use USB tethering
Hi everyone. Need help configuring T-Mobile Galaxy S21 android phone to use USB tethering for my RAX54 router. Thank you. Tommy
Something to contact T-Mobile or Samsung about.
I don't think USB tethering is supported since the USB port on the router doesn't support any internet services. The RAX router requires use of the WAN port connected to a ISP modem or ONT for it's internet services.
- tommy0629Aspirant
Furrye38:
Thanks for your suggestion and comment. 😎
I'm happy to report that I'm connected to the Internet via an ARGOM Tech USB-C to RJ-45 Network Cable Adapter (dongle) connected to the Type-C female connector in my Samsung Galaxy S21 Ultra and using the standard Ethernet tethering option of the phone software. That is all I wanted. Thanks for your time. BTW, Nice setup you have. Chhers. Tommy
Good to know. Glad that works.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
I have seen one user a while ago that used a usb-c to ethernet adapter with a phone that was able to tether that route.
I can't remember if they needed to put the router in AP mode or just ran it straight but they had it working.
Most phone ISP's set a limit on how much data you can use this route through. Something to keep in mind.
- tommy0629Aspirant
Plemans:
Thanks for your comments. Here, I'm validating what you saw. It was a real Plug and Play setup. Router config is as it came out of the box. As far as I know, my mobile data plan is unlimited. Maybe, they will reduce my speed. I'll wait and see.
I'm happy to report that I'm connected to the Internet via an ARGOM Tech USB-C to RJ-45 Network Cable Adapter (dongle) connected to the USB-C female connector in my Samsung Galaxy S21 Ultra and using the standard Ethernet tethering option of the phone software. That is all I wanted. Thanks for your time. Cheers. Tommy
