ifli2's avatar
ifli2
Follower
May 07, 2020
Connecting RAX120 to Vera Z Wave
Just replaced my Asus AC2400 with the Night Hawk RAX120 to improve WiFi connections and very impressed with double speed on the iPhone 11s.  The set up on the mobile app went well and using the previous SSID everything connected using defaults.  I have 4 wired connections over CAT5 (or 6).  My Vera Z Wave controller will not connect to the router.  I am pretty sure it is being rejected as the RAX120 views it as a router.  How do I get over this?  No problem with the Asus, it just plugged and played.
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello ifli2,
    You may try disabling AX mode on the router's settings to see if that would help. Furthermore, if you recently purchased the device, please note that your device is provided with 90 days of complimentary support from our support team which you may access using the link below.
    https://www.netgear.com/support/default.aspx
    Christian
