BJ888
Mar 01, 2021Follower
D-Link wifi extender with Netgear RAX45
I recently replaced my D-link router with a Netgear AX4300 Model#RAX45
I had a D-link wifi extender (DAP 1330) that I had been using to boost the signal out to a room farther from the router. Once I had the Netgear router going I tried to plug the D-link back into it's spot, but it's not finding the signal and won't connect. Will it work with my new router? If so, do I just need to reset it?
Thanks for any help,
Brandy
1 Reply
You can try a factory reset on the dlink extender.
but you might get more help on the dlink forum for how to setup their extender.
