Jayhawkeye3's avatar
Aug 17, 2019
Devices won’t connect?
Hello! Hoping someone can help me out, as I’m definitely not smart when it comes to these types of things.
I recently purchased an AX8 router and installed it in my home, which has U-verse cable and gigabit service.
We set the modem to AP mode and used the smart connect setting to combine the 2.4 and 5 channels.
Since then, several devices wouldn’t connect (blink, Arlo which both use 2.4 only; Vivint security which is 5 only). I turned off the setting so we have both 2.4 and 5 available, and the devices connected but not without issue.
Additionally, all new devices show a wireless connection and full signal, but there is truly no connection (eg online searching or apps show no connection). In fact, my work laptop doesn’t even show my home network as an available network!
Surely I have a setting wrong or there is a firewall issue...or something.
Any ideas?
TIA!
  • Note even some devices like Vivint (5) and arlo (2.4) disconnect a day or two after connecting just fine. Both of them can’t find WiFi today when they were set up two days ago and worked for 24-48 hours without issue.
  • michaelkenward's avatar
    michaelkenward
    Is that the RAX75 or RAX80? Both are "AX8".
    What is this "modem"?
    Modems don't usually have an "AP" mode. That is a way of using a router in a different mode. (You can use some modems as an AP, but then they cease to be modems)
    Some wifi devices have a hard time living with 2.4 GHz and 5 GHz on the same SSID. This is down to the people who wrote the routine it takes to connect. They "forgot" to design their kit for the increasingly popular use of "mesh" wifi.
    Some people turn off 5 GHz temporarily, connect to the 2.4 GHz and then turn the 5 GHz back on. Or they temporarily use separate SSIDs.
    Do you mean the laptop cannot see the wifi?
    If it is a Windows laptop, it may think you are joining a "public" network.
    You may need to tell Windows that you are on a "private network".
    • Network and Internet settings
    • Network Status
    • Change Connection Properties
    • Network Profile
    • Private
    • Jayhawkeye3's avatar
      Jayhawkeye3
      Tutor
      Yes it’s the AX80.
      Sorry, I mean we have the netgear set to AP mode. It’s hard wired to the U-verse router, but we have the WiFi on the U-verse disabled, So the only WiFi signal in the house is coming from the netgear.
      The reason I turned both 2.4 and 5 back on is because when I had them combined using the smart WiFi netgear setting, many devices dropped altogether and could not reconnect.
      Now when I have both signals available, the arlo can connect to 2.4, the Vivint can connect to 5, etc. however, after a day or so they all drop again.
        Jayhawkeye3
        Tutor
        Also, on my windows laptop, the settings are fine. I’m able to connect to other private WiFi networks with no issues. For my WiFi however, the laptop doesn’t even see it as an option.
        Also, our home google is now completely down. Was working just fine yesterday and now can’t connect to the internet.
        Essentially what I’m seeing is this router is slowly booting off various devices after I have them set up and working for a few days.
