james2021
Mar 15, 2021Follower
Difference between AX1800 model# RAX10 and AX1800 model# R6700AX
Hi,
Could someone please explain what's the difference bettween Netgear router model RAX10 and model R6700AX ? I tried Google but got no answer. Both are the same identical to me, I bought RAX10 instead of R6700AX, thought higher price is better product.
I used Verizon fios-g1100 before, and can block access at certain time, but RAX10 didn't have parrental control feature.
Which model Netgear Nighthawk model# have parent control feature?
Thanks for your inputs.
James.
Some of the newer netgear router don't have parental controls. They *might* get them but nothings been confirmed/released yet.
The R6700 (there isn't an AX version) is a midlevel AC router.
AC1750 (450Mbps @2.4GHz + 1300Mbps@5GHz 11ac)
The RAX10 is a base model AX router.
- 2.4GHz: 600Mbps, 40/20MHz1024/256-QAM
- 5GHz: 1200Mbps, 80/40/20MHz 1024-QAM
- 5GHz: 1200Mbps, 80/40/20MHz 1024-QAM> The R6700 (there isn't an AX version) is a midlevel AC router.
