bballdak12's avatar
bballdak12
Difference between RAX15 and RAX20? AX1800
Looking at the Ax1800 wifi 6 router
Whats the difference between the Rax15 and Rax20? I see that on Netgear's website the Rax20 is more expensive but I can't find a difference between the two.
  • plemans's avatar
    many differences but to narrow it to a few.
    RAX15= dual band.
    • 2.4GHz: 600Mbps, 40/20 MHz 1024/256-QAM
    • 5GHz: 1200Mbps, 80/40/20 MHz 1024-QAM
    RAX200=triband.
    • 2.4GHz AX: 4x4 (Tx/Rx) 1024 QAM 20/40MHz, up to 1.2Gbps
    • 5GHz AX: 4x4 (Tx/Rx) 1024 QAM 20/40/80/160MHz, up to 4.8Gbps
    • has a 2.5g ethernet port.
    • bballdak12's avatar
      bballdak12
      Not the 200
      I'm still referencing the AX1800
      They have two models for it. One is a RAX15 and one is a RAX20
      • plemans's avatar
        If you look up the RAX15 and the RAX20 with the fcc report, they're identical. The naming difference is marketing.
        sorry, read to fast and read rax200 not rax20.
